The Last Brake Line Connection Work 4-1-13
In Progress Ready With all Materials & Tools
Drilled and Fittings in Place
Doing the Flares on the Inside lines
What's left to the front of the car...
Flares Done Under the car to the OEM Brake line to the rear brakes and connected
Finished connection inside the car to the rear brakes...
New Brake Master and Bleeding 4-6-13
Getting Ready to bleed the brake lines...
Remove the Wheel and open the Bleeder
Filled but No Brake Fluid Out of the Master Cylinder
Removed Reservoir for Inspecting and Cleaning
My Homie Beto Come to help on the Bleeding Process
Old Brake Master Cylinder was defective, Just Buy a New One...
Doble Check All Fittings and Conections To Avoid Leaks...
That's Me Doing the Bleeding Process with the Brake Pedal Everything was Great, with no Leaks!
Late Night Transport 4-7-13
The Car is Ready At the Trailer...
My Kid Gabito Is Ready For The Trip!
After Few Hours one Stop prior to Up Hill to make sure everything is ok and belts are tight...
Arriving...
Leaving the Trailer With the Car on it...
Night Work At Maniatico AutoPaint 4-7-13
EG Relection on My AE101...
Me Doing Work...
Leaving the Car With The EG...
Long Trip Back to Home... The Taco Needs Refill...
Toms Wheelset Redone Work 5-2-13
Disassembly the Centercaps...
Choosing the same powder coating as this other Drag Wheels
Tom's Original Finish
Center Caps & Valve Stems Removed...
OEM Engine Harness 5-18-13
Engine Harness For New Swap Conversion Harness
46 Toms Center 5-20-13
Looking To Get New Bolts
Disc Rotors Arrived 5-20-13
