benvanderlem Posted June 17, 2017 Report Share Posted June 17, 2017 Currently doing a sr20 conversion into a ke30, just wondering what the best radiator and inter cooler to use for this conversion. Quote Link to comment Share on other sites More sharing options...
SloRolla Posted June 17, 2017 Report Share Posted June 17, 2017 Just a guess, but whatever works man, just grab one from an Silvia or something. Some people have used Commodore rads for it. Quote Link to comment Share on other sites More sharing options...
maccat01 Posted July 15, 2017 Report Share Posted July 15, 2017 The shiny ones work the best :-D But seriously, KOYORAD are making some super sweet super thin radiators. I bought my s2k KOYO from the states shipped for $400 AUD. Ill see if I can dig up the sellers bis name. The Chinese eBay aluminium ones for KE30 look ok, but they are very thick and ive heard of people having issues with the copper core reacting with the alumnium tanks, because SCIENCE!!!! If you running 'X' engine try to run a rad same size or bigger capacity then the stock one. Also keep in mind the difference between cross flow and down flow, then also double flow. Regards macca Quote Link to comment Share on other sites More sharing options...
maccat01 Posted July 15, 2017 Report Share Posted July 15, 2017 Also I been doing ALOT of research on intercoolers due to wanting to run an old roots type blower... Air to air are great but in some instances air to water are better. Air to water however, are harder to setup due to needing a cooling core, a water pump, a heat exchanger, extra tubing and also coolant... Check out laminova cores if you want different some ideas. Regards macca Quote Link to comment Share on other sites More sharing options...
