April 27, 20197 yr comment_717665 Hey guys I'm new to corollas but recently picked up a 89 ea93 sx hatchback and wanted to do a airbox delete and put a pod filter on it the only drama is that there is all sorts of sensors and vacuum hoses on it. Question 1 - what are these ? Question 2 - can i remove them all ? Report
April 27, 20197 yr comment_717672 My 2 cents don’t do it. The various sensors are there to give the ecu info it needs to run the engine optimally, and keep it idling properly. It probably already has a cold air feed from inside the guard. Pod filters make it noiser, suck hotter air inside the engine bay, plus it’s a defect if you get pulled over. A better bet is to find a high flow element for your stock airbox, and change it regularly Report
