May 31, 20206 yr comment_723062 Hello. Did the ke20/25 come with different styles of swaybar? I have a ke25 that I'm installing a 2tg into, and it has a straight swaybar and it seems extremly tight fit. Had the same engine in a ke20 some years ago with a different swaybar that cleared the oil pan easy.. Do i need to change my swaybar or modify it? Anyone with ke2x with 2t and straight swaybar that knows if it will fit with some fiddling? Report
June 3, 20206 yr comment_723101 My recollection is that you can use a TA22 swaybar which is obviously designed for a T engine. Can’t comment on width. I have a TE27 bar but haven’t compared it to a KE25 bar. Should be able to pick up a standard TA22 bar easily and cheaply. Try the Aus 1st gen Celica forum on FB Report
