andrew Posted May 8, 2004 Report Share Posted May 8, 2004 last night i found some injector specs on google for yoda modas engine / inj colour / cc/min / impedance 4ke / light green / 145 / 2.4 1g / green / 145 / 2.4 4age / dark grey / 182 / 2.0 3sfe / dark grey / 200 / 1.7 22re / orange / 200 / 1.7 4age / pink / 200 / 2.7 3sfe / dark blue / 200 / 13.8 22re / orange/blue / 200 / 13.8 4age / blue / 210 / 2.4 4age / biege / 213 / 13.8 22rte / yellow/orange / 250 / 1.7 4age / green / 250 / 13.8 4age / violet / 250 / 13.8 3sge brown / 250 / 13.8 22rte / pink / 295 / 1.6 3sge / green / 295 / 13.8 3sge / pink / 315 / 13.8 4agze / red/orange / 365 / 2.9 3sgte / black / 430 / 2.9 now. as you probably know there are two main impedance gruops. low resistance and high resistance. for example if your car ran 1.7 ohm injectors, you could fit injectors that run 2.9 ohms,as long as they are the same shape and size. hmmm 3sgte injectors in a 4ke.......oh yeah! anyway there are 2 different 22re injectors of the same cc/min, but the impedance is different, probably between year models 1984 and 1985. my prob is i can't tell what colour mine are, they are just plain white. and so are my spare 22re injectors. so i can't tell if my impedances match with the 4agze injectors i got off junior. does anyone know how i can overcome this problem? can injector specialists tell or test what impedance they are??? hope this info helps some of you out there Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted May 9, 2004 Report Share Posted May 9, 2004 http://www.autospeed.com/cms/article.html?&A=0102&P=1 Quote Link to comment Share on other sites More sharing options...
andrew Posted May 9, 2004 Author Report Share Posted May 9, 2004 yes thats where i got it from but i don't understand why my injectors don't match any colours on the chart. so i cannot determan whether they are compatible with my ems Quote Link to comment Share on other sites More sharing options...
NickZ Posted May 9, 2004 Report Share Posted May 9, 2004 Use a multimeter set on ohms and see what ohms they read. they will be approx the ohms but not dead on. Quote Link to comment Share on other sites More sharing options...
andrew Posted May 9, 2004 Author Report Share Posted May 9, 2004 so i just put the earth side of the multimeter on one plug and the positve on the other? does it matter what polarity to test this??? if not,sweet. i have a multimeter Quote Link to comment Share on other sites More sharing options...
Super Jamie Posted May 10, 2004 Report Share Posted May 10, 2004 no injector resistance is not polarised Quote Link to comment Share on other sites More sharing options...
andrew Posted May 10, 2004 Author Report Share Posted May 10, 2004 its all good. i took the 22re and gze injectors to a injector shop in my suburb and they said they will go with my ecu (as i will keep the stocker until i can afford an aftermarket ecu) and he's flow testing them and cleaning them for f@$k all. sweeeet! :) Quote Link to comment Share on other sites More sharing options...
