Fixing an aftermarket RPM meter to 7K-e engine
Hi Guys,
I need to fix an aftermarket RPM meter to 7Ke engine. I am suppose to get the signal  wire from ignition but worried that i will burn something out. If someone can help me to select the signal wire will be very much appreciated. It would be wonderful if anyone can share an image of the signal wire from ignition.
Cheers.
In a KE70 it comes off the coil negative, the black wire going to the distributor.  There is a dedicated wire for it in the stock loom, even though the standard KE70 didn't have a tacho. You might find it in your wiring, or run a fresh wire from the coil -ve.
Thank you for the reply. My coil has only 2 wires apart from the HT connection to the distributor and when tested with multi-meter, they show + voltage with chassis ground. But one wire shows a little lower voltage than the other.
