HasithaR Posted February 6, 2022 Report Posted February 6, 2022 Guys, Has anyone experimented with the communication port of 7Ke computer box? I am interested to know if i could use a laptop to read engine data like from an OBD port? any ideas or experience sharing will be much appreciated. Thanks. Quote
Banjo Posted February 7, 2022 Report Posted February 7, 2022 Hi Hasitha, Good luck with that one. Even if there was a computer program to communicate with the ECU, you would probably need an olde DOS based PC, to run it. I think those olde ECUs, were pretty basic, & just indicated faults & diagnostics in the ECU, by blinking the engine warning light a number of times, where you counted the blinks, & the referred to a manual. I found an olde 7KE manual on the net, which you might care to read, & see if that helps you. https://www.scribd.com/document/540871784/Buku-Manual-Toyota-7ke-Kijang-Kapsul-18-Efi-Compress Cheers Banjo Quote
HasithaR Posted February 7, 2022 Author Report Posted February 7, 2022 Thanks Banjo. Let me take a look at this document also. will update you. cheers... Quote
