KE55 wiring diagram
Hi all,
Searching for a KE55 wiring diagram if anyone has a good, clear copy of one please.
I have done a search of this site, and found a link to one, however I can't get the link to work.
Hi Adam,
                All the Corolla's around that era, had very similar wiring diagrams. Some of them, are hell to read, as there are so many fine straight lines.
http://www.retrojdm.com/ScanViewPage.asp?ScanID=40&Section=Supplement&DPI=100&Filename=S5-03 - Electrical Wiring Diagram for Models KE10(L), 15(L), 16V(L), Series.jpg
This is how they should all be presented.  The real problem, if you are tracing a circuit; as wire colours vary, depending where the car was assembled.  The Australian assembled ones, put together by AMI in Melbourne were a typical example. If they ran out of a particular colour wire, they just added another colour.  i rewired my engine bay loom, once, & found the colour changed on some wires from one end to the other, with a join, in a wrapped harness.  I only found it, when I unwrapped the loom !
Good Luck !   Have you got a specific electrical issue, or are you "rewiring" ?
Cheers Banjo
