Darrensan Posted Tuesday at 07:20 AM Report Posted Tuesday at 07:20 AM Hi, I understand that the KP61 Starlet rack etc is a popular choice for upgrading the steering in a KE10. Would the steering rack from a KE70/AE71 be a possible fit? with some mods? Or are there any other racks that may be a possibility? I plan to keep the factory column but upgrade to a rack. Are there any problems with this way of thinking? Any advice helps. Cheers Quote
parrot Posted Wednesday at 07:26 AM Report Posted Wednesday at 07:26 AM It’s more complicated than that, and the attraction of the Starlet rack is its narrowness with resultant reduced impact on steering geometry, which can be a problem with wider donor racks. A basic understanding of recirc/worm steering will tell you that retaining the standard steering column isn’t an option if you go rack and pinion. These days you may want to look into electric steering and so forth. Still requires mechanical attachment to the wheels however. As ever, worth a chat to an engineer sooner rather than later once you understand the issues, and source of necessary parts Quote
Darrensan Posted 19 hours ago Author Report Posted 19 hours ago Thanks for the reply Parrot. Ok, advice taken. Will talk to my engineer about what I can do. Cheers Quote
parrot Posted 17 hours ago Report Posted 17 hours ago Do update your thread when you have an answer. I'm sure the info will be relevant to other application also. Quote
