5 hours ago5 hr comment_738754 Hey all! I hope there's enough people here still to give me some advice. I just bought a 1983 Corolla Wagon that I plan on modifying to my liking, but I wanted someone to look over my parts list for lowering the car before I start buying things. I did my research in the KE70 Lowering thread, and I think I have a decent understanding of the parts I need. I was just hoping someone who has done the work can give me advice on whether or not these parts are correct.Front:Original Strut Housings and top mountsTechnotoytuning Weld-on Coilover kitAW11 MR2 Rear StrutsAe86 LCAsCelica WheelsWheel SpacersRear:3” Rear Leaf Spring Lowering Block KitI've never done suspension work like this on my own, so this is all new to me. I bought this car as a vessel to learn how to work on cars, body work, suspension, engine work etc.. Any help is greatly appreciated! Report
2 hours ago2 hr comment_738755 Have a look at the distance between the diff and the bump stop above it, and think about how much movement you want the car to have when you ride over a bump.That will be with an empty car I expect, and you won't be carrying anything in it when its lowered. What you decide for ride height will give you the comfort and the handling, because it will hit the bump stop with a back-bruising 'whack' and instantly transmit the weight of the car to the tyre sidewalls, who usually give up and the car jumps sideways.Buy the 3" lowering kit but start with some home-made steel boxes half that and see what happens.Run your coilovers with stock LCAs first, just use a spirit level to measure camber at home, and check how much tie-rod end thread is used. Using longer LCAs will give increasing camber and mean less and less thread holds the steering arms in.This was my KE70 on stock 175/70 tyres with just cut rear springs....and this is with BCR weld-on coilovers, their rear springs and 185/70 tyres on 14" rims.That car does 80km a day through countryside on B-grade roads so I need suspension that works well. The BCR rears were too hard so I went back to the stock springs and kept the BCR adjustable shocks. If your wagon is just a show pony for occasional track days you can go lower.What about sway bars? I run a stock front and an upgraded Celica rear. You might not need that much extra as the leaf springs will not have the grip of the 5-link.Is the rest of the body in good condition? Report
