August 8, 200620 yr comment_133069 Ive been looking around for a wile now and there no info on how to install them. I was going to ask the windscreen guy to put it in but he wanted about 120 and said it wasnt worth it, he told me how to do it and now i carnt really remeber what he said :rolleyes: he said something about putting 'rope' around the rubber seal and using selant and belting it in? Come some help please J ps ae71 Report
August 8, 200620 yr comment_133070 Ive been looking around for a wile now and there no info on how to install them. I was going to ask the windscreen guy to put it in but he wanted about 120 and said it wasnt worth it, he told me how to do it and now i carnt really remeber what he said :rolleyes: he said something about putting 'rope' around the rubber seal and using selant and belting it in? Come some help please J ps ae71 when i was watching them do my windscreen they cleaned up the contact area with a grinder they put shit loads of black glue/sealant shit pushed the screen in held it the for 5 mins and boom it was done took 10 mins but hey this was a mazda bodge job. ;) Report
August 8, 200620 yr comment_133071 Yeah It's pretty easy if you have done it before, you have to wrap rope around the rubber and pull it so it lips over the edgeing when you go around the window. You need someone on the outside to help keep pressure on it.. Report
August 8, 200620 yr Author comment_133072 "pull it so it lips over the edgeing when you go around the window" what do you mean? ;) also how thick does this rope have to be? Report
August 8, 200620 yr comment_133074 You are not using the rope for the titanic, Just stuff about the thickness of standard 12v automotive wire. It has to be strong enough for you to pull on it without it wanting to break. Pretty sure you have to do about 2 laps of the rubber in 2 different grooves it has. You then put the windscreen down on the back and pull the rope from the inside to lip the rubber over the edge and follow it around the window till you pull the rubber in. Then go around and windscreen with a sealer gun and seal it. Then you have to press the rubber down around the whole thing.. Report
August 8, 200620 yr Author comment_133082 so you put the seal around the windscreen wrap the rope around the seal put screen on car pull rope and push screen down seal the rubber between glass ? souldnt some sealent go between the seal the metal? sorry its just really hard to picture Edited August 8, 200620 yr by Jason Report
August 8, 200620 yr comment_133140 you seal it with windscreen sealer after the window is in properly.. Report
