Search results
Page title matches
Page text matches
  • KE35 and 55 Hardtops, From factory, Are 1.5inches (38mm) LOWER than a KE30/55 sedan. ...Wagons/Panelvans, From factory, Are 5/8's of an inch (15mm) HIGHER Than a KE30/55 sedan.
    441 bytes (75 words) - 07:09, 13 October 2011
  • this is my FAQ on how to put a hilux/4 runner, diff into a ke30-ke55.
    418 bytes (86 words) - 09:18, 30 July 2007
  • ...for, however make sure the offset is right. R31 Skyline 15" rims will hit KE30 struts. I believe 110mm is about the maximum inset you'd want to run for fi ...an axle swap, you will also need the drum assembly from the donor axle, as KE30 drums and backing plates are different than KE20 and KE10 drums and backing
    3 KB (601 words) - 10:16, 26 April 2005
  • {{MenuBlock|Title=Third Generation - KE30/35/36{{anchor|3x}}|colspan=2|Image=Ke30 mp.jpg|Content=
    1 KB (215 words) - 10:00, 14 September 2012
  • ...Trewern welded a KE30 caliper backing plate onto the diff housing and used KE30 calipers. I think you could use RX7 calipers and modify the disc mount so i
    2 KB (396 words) - 09:02, 7 September 2008
  • ...as they are. You will need to cut the lower spring perch off and re welded KE30 or KE55 lower spring perch on. You will need to use the matching Top spring ...ng perch re welded or convert to coil overs. and use the top hats from the KE30 or 55.
    2 KB (387 words) - 12:49, 12 January 2011
  • Information courtesy of KE30 KE35 KE55.
    649 bytes (104 words) - 08:36, 24 November 2010
  • <tr><td>KE30</td></tr>
    2 KB (363 words) - 15:14, 26 May 2008
  • ...haft unis are the same, so it's no big drama if, for example, you put a 6" KE30 center in your 6" KE25 diff and the pinion is different. ...ffic light launches, weekend racetrack action, etc) behind a 96kw 4AG in a KE30.
    6 KB (840 words) - 11:42, 30 July 2006
  • Giving your KE30/KE35/KE55E or KE55S a boot release is quite simple. Here is the finished latch in my KE30 Sedan.
    4 KB (787 words) - 03:50, 22 June 2008
  • ...ging from smaller disc to larger disc, you will need caliper mounts from a KE30 or KE55, as KE70 caliper plates have a different stud pattern. On most KE1x Alex Bates has written a nice howto for upgrading to KE30 brakes. If using KE55/70 brakes, use those discs and calipers instead, with
    10 KB (1,927 words) - 12:33, 22 November 2006
  • *KE30: A little larger, 4x114.3 (KE70 stud pattern) unsure of if 12's will fit, D *KE70: The same as ke55, Thicker than KE30 with Girlock brake calipers. 4x114.3
    4 KB (797 words) - 11:42, 18 September 2012
  • ...ndards inquiring aboutr basic Corolla upgrades. A 5K conversion into a '75 KE30 is as simple as changing the engine number. On the other hand a 5K into a D
    3 KB (517 words) - 11:02, 26 May 2008
  • ====KE30/35/36/38==== *[[Series:K/Model/KE30/35/36/38/Template|Template]]
    9 KB (1,341 words) - 09:31, 28 April 2014
  • | Corolla KE30
    3 KB (344 words) - 04:05, 31 May 2008
  • TA22 & T18 T50's share a "ke30-55" shifter position. The AE86 and AE71 T50's have a "ke70" shifter positio ...at I am using has the same shifter position as a ke70, so fitting one in a ke30-55 will require a bigger shifter hole.
    6 KB (1,130 words) - 02:23, 25 September 2015
  • <b>KE30/55</b> [[KE30/35/36/38/50/55/55p Suspension]]
    9 KB (1,265 words) - 09:49, 14 September 2012
  • ...run-on ([[Dieselling]]), I suspect that this came in around 1975 (with the KE30), however some later model cars have been released from the factory with no
    6 KB (1,015 words) - 02:02, 16 September 2012
  • KE10, KE20, KE30, possibly KE55 w/ 4 Spd
    11 KB (1,693 words) - 02:21, 16 September 2012
  • ...stereo and big ignition you probably need more amps, especially in a KE10-KE30 with a tired little 35A Denso. There are upgrades available to take a Bosch ...they're both bound to break soon. Nikki had both diffs in her 4AGE-powered KE30 and they both stood up to the punishment she gave them.
    68 KB (12,724 words) - 02:28, 16 September 2012
View (previous 20 | ) (20 | 50 | 100 | 250 | 500)
