ohnoes
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> 1st Gen 4afe Vs 2nd Gen 4afe
Womble1972
post Apr 27 2010, 09:36 AM
Post #1
New Member
Group: Members
Last Active:
2nd July 2010 - 08:34 AM
Real Name: Rod
Hi i am rod and I'm new here.
I'm not real good with engines and mech but can swing a spraygun so any questions there i can help just message me.
I am fitting a 4afe into a ae95 i thought the two engines are the same but there is a few differences like knock sensor and a extra port about the size of the ten cent coin below the inlet port for cylinder 1,and what looks like a 7A grey fuel injectors.
I think i have a 2nd gen 4AFE by accident.
Does anyone know what the little port does? it feeds back into the inlet manifold.
What are the other differences i have not found?
Any help would be great.
Rod
This post has been edited by Womble1972: Apr 27 2010, 10:54 AM
Go to the top of the page
+Quote Post
Hiro Protagonist
post Apr 27 2010, 10:58 AM
Post #2
World's Greatest Sword Fighter
Group Icon
Group: Donor
Last Active:
Yesterday, 07:29 PM
Real Name: Ian
Easy way to tell them apart is the early 4AFEs look like a 4AFC, and have the injectors in the head. Late 4AFEs look essentially identical to a 7AFE, with injectors in the intake manifold
A bit unsure on what you are describing as fas as that extra hole is concerned, does it lead into the manifold/port? Photos would help.
+Quote Post
Womble1972
post Apr 27 2010, 02:10 PM
Post #3
New Member
Group: Members
Last Active:
Real Name: Rod
Awesome i will take photos tonight thanks for help.
+Quote Post
GJM85
post Apr 27 2010, 02:55 PM
Post #4
Group Icon
Group: Donor
Last Active:
Yesterday, 08:58 PM
QUOTE (Womble1972 @ Apr 27 2010, 09:36 AM) *
Hey I own a 4a-fc. It also has an extra port that runs from the manifold to the head. Well it actually flows into the manifold from the head. In the 1st exaust port there is a small hole which takes exaust gases back through the head and up into the inlet manifold. On the carbi motor the manifold is water cooled and the gases help warm the manifold and to vaporise fuel when the engine is cold.
As Hiro previously stated the 1st phase FE motor has direct port injection and there for has no need for early vaporization, where the 2nd phase FE motor has manifold injection and therefore may require assisted heating and fuel vaporization on cold starts.
This post has been edited by mirage1172: Apr 27 2010, 02:59 PM
GJM85's KE20 Build
The Police Evasion Theory: (a theory of probability) "...less time your on the road, less chance you'll get caught. Therefore, go faster!"
+Quote Post
Womble1972
post Apr 27 2010, 06:56 PM
Post #5
New Member
Group: Members
Last Active:
Real Name: Rod
Ok I'm back with pictures
sorry i was wrong the new engine has knock sensor but no extra port.
This is the new engine no port.
This is the old engine with port
Old engine looks like this
New engine looks like this (does not have the alloy ribbed cover like 7A)
Old Manifold with extra port.
new manifold without port.
What do i have here a second gen 4afe? or something else.
again thanks in advance.
+Quote Post
Hiro Protagonist
post Apr 27 2010, 08:20 PM
Post #6
Group Icon
Group: Donor
Last Active:
Yesterday, 07:29 PM
Real Name: Ian
It still has the early 4AFE cam-cover, which to me says it's not a late 4AFE.
The EFI-S on the cam cover does have me intrigued though, import?
From the looks of it, the location of that hole would indicate external oil drain to me, but nothing corresponding on the head. Either that, or it's for the PCV system.
+Quote Post
Womble1972
post Apr 28 2010, 07:29 AM
Post #7
New Member
Group: Members
Last Active:
Real Name: Rod
Its got carbon build up so i guess the old engine had PCV but the new one does not.
Its either a import or a dog motor made up of parts.
Ill try putting it back together and seeing if it will run.
Thanks for help
+Quote Post
Hiro Protagonist
post Apr 29 2010, 10:02 AM
Post #8
Group Icon
Group: Donor
Last Active:
Yesterday, 07:29 PM
Real Name: Ian
Did a bit of research, the EFI-S sticker (if it is genuine/the original cam cover) indicates that it's a 4AFHE engine from a Jap-spec AE95. The H in Toyota-lingo means that it should be higher compression than the normal 4AFE, and a quick check of Wikipedia confirms this. Also, it has 81kw/142Nm compared to a normal 4AFE 78kw/137Nm. Not much, but if it's a healthy motor you should notice a bit of a difference. Would also explain the lack of port/PCV (Jap-spec emissions are often different to Australian ones)
Still a 1st Gen 4AF*E though.
+Quote Post
Womble1972
post Apr 29 2010, 03:34 PM
Post #9
New Member
Group: Members
Last Active:
Real Name: Rod
Thanks Hiro
Ill talk to the guys who supplied it and see if i can get some background on the engine.
I have got friday off i will put it back together and hopefully it goes back in Sat.
Then we see if it will run.
Thank you all for your help
Rod
+Quote Post
zonz540
post Jul 29 2010, 05:57 PM
Post #10
I'm new here
Group: Members
Last Active:
29th July 2010 - 05:57 PM
Real Name: Landon
QUOTE (Womble1972 @ Apr 28 2010, 11:34 PM) *
Thanks Hiro
Rod
I have an AE95 with the motor you are currently pulling out of your wagon and a 4AFHE ecu. I have been told a few times by knowledgeable Toyota folks that everything is the same on the two engines, compression included. I am interested to know what the differences really are. I picked up the ecu in hopes that the mapping of the engine would just be more performance based and it would be an easy upgrade, but after installing the ecu, the engine will crank, but simply dies just after. The tach will rev to ~6500 rpm before it dies. Ive done some diagnostics, but don't know where to go next. The things i have checked are fuel pump and a small amount of timing (advancing and retarding slightly).
Anybody have any answers?
Thanks!
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version | SEO by MinervaSEO Time is now: 10th September 2010 - 03:18 AM
  Page top
Im4eversmart
