Jul 7 2010, 07:07 PM
Post
#1
New Member ![]() ![]() Group: Members Posts: 11 Joined: 4-July 10 Member No.: 11433 Last Active: 29th August 2010 - 07:47 AM Real Name: guillaume |
hi all, i now a holden nova az93r, the same as an ae93 with the 7afe 1.8l engine. the car is in quite good condition for 270000 km, as the engine is starting to blow a bit of smoke/ using oil and the manifold is cracked, i would like to replace the ageing 7afe for somethin with more power
Jul 9 2010, 11:52 AM
Post
#2
![]() Regular Member ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 427 Joined: 19-December 06 From: Hobart, Tasmania Member No.: 2650 Last Active: 18th August 2010 - 01:46 PM |
No engine swap is easy. I suspect given the large amount of time and money that would be needed to do a 20 valve swap, you would be dissappointed with the result. I personally think a low boost turbo setup on your 7afe (maybe need to be rebuilt?) would be better bang for buck.
-------------------- Cooking
Jul 9 2010, 08:17 PM
Post
#3
![]() Common Member ![]() ![]() ![]() ![]() Group: Regular Member Posts: 150 Joined: 12-January 08 From: Adelaide, SA Member No.: 4985 Last Active: Yesterday, 11:31 AM |
Swap shouldn be any different to doing a rolla conversion, to which alot of people have done.
As for parts, local toyota dealer, given you have a good one, will be able to help you out for parts Bugz -------------------- AE82 Twincam.
A work in progress.... |
Jul 9 2010, 11:03 PM
Post
#4
No engine swap is easy. I suspect given the large amount of time and money that would be needed to do a 20 valve swap, you would be dissappointed with the result. I personally think a low boost turbo setup on your 7afe (maybe need to be rebuilt?) would be better bang for buck. o ok thats an idea, if i rebuild the 7afe to keep it reliable with a turbo set up should i use any aftermarket parts like headgasket, bearings, maybe stronger internals? or are the 7afe's already a fairly strong motor? i'm not very familiar with turbo's i'm still an apprentice and is there turbo kits on the market? |
Jul 11 2010, 07:01 PM
Post
#5
![]() Well Known Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 1003 Joined: 6-December 05 From: Endeavour Hills Member No.: 1021 Last Active: Today, 09:27 AM |
No engine swap is easy. I suspect given the large amount of time and money that would be needed to do a 20 valve swap, you would be dissappointed with the result. I personally think a low boost turbo setup on your 7afe (maybe need to be rebuilt?) would be better bang for buck. it wouldnt be that hard to do though? you just swap everything over and the wiring should be pretty straight-forward. Considering the price of getting the existing engine out and getting it rebuilt the front cut can be quite affordable for a good power gain. -------------------- |
Jul 11 2010, 10:09 PM
Post
#6
Well Known Member ![]() Group: Global ModeratorPosts: 2375 Joined: 23-January 07 From: Brisbane Member No.: 2885 Last Active: Today, 01:00 PM |
it wouldnt be that hard to do though? you just swap everything over and the wiring should be pretty straight-forward. Considering the price of getting the existing engine out and getting it rebuilt the front cut can be quite affordable for a good power gain. Yes I'm with Sam, super easy as conversions go, especially with a halfcut, you'd have to be a moron to cock it up, especially with rollaclub here to help you a bit. |
Jul 13 2010, 11:04 AM
Post
#7
Well there you go. The 20 valve swap IS a very common one. You would have a lot of help available if you do one. Maybe see if you can go for a ride in one before you make up your mind? 7afe turbo? There was a limited run, Australia only AE 111 (I think) Corolla Sportivo that ran a 7afe turbo setup from the factory, so it definitely can be done. I have heard that replacement parts for this model are hideously expensive, so don't expect to be able to walk into Toyota and just buy turbo bits. There are a couple of guys on here with these cars too. Do the research and either way you will be happier with the result. Peace, Mark
Jul 13 2010, 04:22 PM
Post
#8
Jul 13 2010, 09:09 PM
Post
#9
Well there you go. The 20 valve swap IS a very common one. You would have a lot of help available if you do one. Maybe see if you can go for a ride in one before you make up your mind? 7afe turbo? There was a limited run, Australia only AE 111 (I think) Corolla Sportivo that ran a 7afe turbo setup from the factory, so it definitely can be done. I have heard that replacement parts for this model are hideously expensive, so don't expect to be able to walk into Toyota and just buy turbo bits. There are a couple of guys on here with these cars too. Do the research and either way you will be happier with the result. Peace, Mark yea i'v herd of those 7afe turbo. i will try and test drive a 20 valve corolla then, i woudn't mind test driving a 7afe turbo but their is not many of them around. if i go with the turbo i would probably go aftermarket turbo kit, do you no of anyone who makes those turbo kits? |
Jul 13 2010, 09:52 PM
Post
#10
hey thanks for the info there's lots of good stuff in there.i'm still not sure if i'm gona put a turbo on the 7afe or get a 4afe 20v i'll do a bit more looking around. |
Jul 13 2010, 10:06 PM
Post
#11
sure thing.
Good idea, take your time, try some cars and do your research into it. Your not in Victoria by any chance are you? -------------------- |
Jul 14 2010, 06:06 PM
Post
#12
Jul 14 2010, 11:16 PM
Post
#13
ah bummer, I could of taken you for a spin in something with a 20V
Jul 15 2010, 07:00 PM
Post
#14
Jul 15 2010, 08:19 PM
Post
#15
yeah great, with an aftermarket ecu exceptional, it's like a different engine
Lo-Fi Version | SEO by MinervaSEO | Time is now: 9th September 2010 - 01:03 PM |
Im4eversmart | ||
