littleyellowbeast
    9
  • Real Name
    Mike
littleyellowbeast's Achievements
  1. I don't want to reuse my original rubbers, I want to make sure I have the correct parallel 0 degrees of offset, from your picture it looks like the rubbers don't meet the crossmember flush its off a couple degrees or its just the way the picture looks. I bought some casting compound from McMaster Carr that is a 60A hardness which is close to the consistency of car tire rubber. I want a thinner rubber mount so I get better torque response. I'll post pics in my build thread and link to it from here when the compound arrives and I'm able to mock up the engine. I still need to pull the alternator and modify the mount, its not bolt in ready for the blacktop. There are 2 indexing pins I'll need to drill the mount to allow the pins to recess into the mount. I'll post pics of this also. Its hard to get the point across in words. I'll link all of it up on my build page. Thanks again for all your feedback guys I appreciate it, Mike
  2. That there is an empty trunk, and my shiny new fuel cell.
  3. my name is mike, my ke30 was all original, so far ive pulled all the fuel lines removed the tank, pulled the engine and tranny and gutted the interior. original owner cut the springs so I'm pulling em off to swap in originals to give it better lift. with the extra weight of a 4age i may need toupgrade my struts? any thoughts
  4. Thanks Silverra! I emailed Scott through the weblink above. So I have 2 fail points, the seals and the moulding are bad. www.toyodiy.com lists the moulding parts. I went to a local toyota dealership and they said that these parts aren't manufactured anymore and that it would be impossible to source. The parts guy didn't seem very interested to offer any assistance so I'm not sure if he was just being lazy and blowing smoke or if he was being serious. Any thoughts on where I could locate new or aftermarket moulding ? These are the parts for OEM below; Rear Window Moulding parts 75571 MOULDING, BACK WINDOW, OUTSIDE UPPER 75571‑12090 KE3*, TE31, 37.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $29.09 75572 MOULDING, BACK WINDOW, LOWER 75575‑12040 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $25.62 75575 MOULDING, BACK WINDOW CORNER, UPPER RH 75581‑12010 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $7.13 75576 MOULDING, BACK WINDOW CORNER, UPPER LH 75581‑12010 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $7.13 75577 MOULDING, BACK WINDOW CORNER, LOWER RH 75543‑12010 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $6.11 75578 MOULDING, BACK WINDOW CORNER, LOWER LH 75543‑12010 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $6.11 Windshield moulding parts; 75531 MOULDING, WINDSHIELD, OUTER UPPER 75531‑12120 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $29.09 75532 MOULDING, WINDSHIELD, LOWER 75535‑12050 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $21.65 75533 MOULDING, WINDSHIELD, OUTSIDE RH 75533‑12140 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $14.08 75534 MOULDING, WINDSHIELD, OUTSIDE LH 75533‑12140 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $14.08 75535 MOULDING, WINDSHIELD CORNER, UPPER RH 75541‑12050 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $4.39 75536 MOULDING, WINDSHIELD CORNER, UPPER LH 75541‑12050 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $4.39 75537 MOULDING, WINDSHIELD CORNER, LOWER RH 75543‑12010 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $6.11 75538 MOULDING, WINDSHIELD CORNER, LOWER LH 75543‑12010 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $6.11 Thanks again for everyones help I really appreciate the responses! This community rocks!
  5. Hi all! I have bad seals and rubber on my windshield , rear window. My front windshield is cracked and needs replacement also. I live in washington state and I know some of these parts aren't even manufactured anymore. Does anyone know someone or a business that can fabricate new seals or rubbers? Any recommendations for aftermarket replacements would be fantastic. My baby is a little ke30 2d sedan. I really appreciate any help, Mike
  6. Thats SWEET! My 4age blacktop is on the way, I'll have to order those mounts now that you confirmed they are compatible. My little yellow beastie has some dents and some leaky window seals but when I'm done she'll be super sweet. Thanks again for the quick response those mounts look like a perfect fit. Mike
  7. I think we talked a little bit about this over PM Sam, but I think this is the right area to post the question. http://www.technotoytuning.com/productdetail.php?p=785 these guys sell mounts for a KP61 / KP60 starlet. Does anyone have specs on the ke30 crossmember vs. kp60 / 61? I am hoping that they may be interchangeable. Thanks everyone for your help!
  8. I read through your post, I wanted to say thanks for posting all of the pictures and information. I just picked up a 77 corolla 2d, it runs great but it has the 1200 cc motor so it is very gutless.
