OBSCENE
    34
Contact Methods
  • Website URL
    http://
  • ICQ
  • Location
    Townsville
OBSCENE's Achievements
  1. Here's the engine bay with new radiator and intercooler in place.
  2. Just wondering if anyone can help me I have fitted a 4agze (from an 88 mr2) to a 67 ke10 and now I want to start fitting an a/c system. What I need to know is how to wire in the engine idle up there are two inputs that I can see which are ELS2-from idle up diode & A/C-From A/C amplifier. I'm not sure which ones to use or what the input voltages are.
  3. Yeah just used a cloth but my lenses were pretty good under the surface.
  4. This was the lense before I polished it.
  5. NOS brake/reverse lense and about 15 minutes polishing the indicator lense with autosol alluminium polish and then meguiars hi-tech yellow wax. Lens came up like new.
  6. Thanks guys I've got a few sets of lights here I might experiment on and see what gives me the best result.
  7. Hey guys just wondering what your experiences are restoring dull tail lights. I've read a few different things you can do which is to sand them progressively smoother and clear coat them or use a tail light dye. Thanks
  8. I'm really after something that doesn't require shortening and won't break easily
  9. Just wondering what would be the best diff option for a ke10 running a standard 4agze with a t50 box? Currently running a standard diff with 4:11 diff gears and considering a disc brake conversion. Thanks.
  10. I have had the radio Suppressor on the coil fail before and I had the same problem that you are describing. Disconnected it and had no more dramas.
  11. Here's a shot of the exctractors finished. Going to be a 2.5 inch system Here's a couple pictures of the gearbox crossmember finished. I have used the factory ke10 crossmember and had some brackets made up to extend it towards the back of the car.
  12. A/C compressor fits pretty good. Engine mount one.
  13. Here is the start of my prototype engine mounts. I am trying to fit the engine so I can run the 4agze factory air conditioning compressor.
  14. Hey everyone I know its been a while since i've actually done anything but now I'm back into it. I now have the engine and box sitting in there and I am about to start the engine mounts. I am going to manufacture an L shaped mount with a brace and run the Land Rover round type rubber mounts for a nice rigid feel. Let me know what you all think!
  15. 5pk 950 & 5pk1030 they are the numbers on mine
