What Other Diff Will Fit A Ke55
hey my stock ke55 auto diff is making a few werid noises and i am having no luck finding a new diff what eles fit's with no mod's anythink bolt stright in????
How Hard Is It To Do A Manual Conversion To A Ke55
hey everyone I'm looking at making my car manual realy soon to my stock 4k auto ke55 buying a 4speed manual tail sharlf pedales flywhell center console what eles do i need????? how long will it take??? any hard part's? eg n cutting anythink... removing anythink from motor??? all help will be great thankz soory about spelling
Lucy The 4Age 55
nice work here mate the 15ich chasser's u had on ur car what were they off??? did they fit stright on or have to use spacer or sothink as when i had a set on my old gemini i have to use spacer's as they wouldnt fit over the hub
Kiama To Bulli
i know this is a heaps old post but I'm heaps keen to meet up n go for a drive
Can U Adjust Steering Column
only a few days now iv had a ke55 b4 and i ned had a problem this one it diffrent
hey everyone a nuther silly Q can you adjust a steering column in a ke55 it seem's to be sitting to fair out and is a lil hard to get into the car just got a bosskit n whell n no diffrence alll help needed
Realy Silly Q But Must Ask About Fuel
can u just leave timing the way it is n just got a good fuel in for if i play with timing will it go better n be better on fuel????
ok thankz for all the imput 98 it is i will tune it better when i get a webber on the old girl n exasut
hey everyone just goy a stock as a rock ke55 what fuel should i use??????????????? do i have to use a valve saver fuild or not?? i had a gemini and i neva had to in them as the alloy head so would want to make sure what i should be useing in the ke55 thankz
What Radiator To Use In Na Ke55
also iv been told the vn commodore radiator are good to put in would this be a good thing to do????
yeah i flush them out aswelll i got told to put my hand on the out side of the radiator to see is the cores were blocked eg hot and cold spot's all felt ok in middle out sides were hoter but.. just waiting for shop's to open for prices if its only 100 for a recore i will do that anyways as some of the fin's are failry messed up
heater house go's around back of motor back inot water pump... off the engine mate.... should i put thermo's on it aswell????
the one i used said 10 min's used it took it for a drive again whent ok then heated right back up its hot here but still yea i am going to put in a temp gauge soon radiator shop opens on tuesday i hope going to see how much to recore thm or clean core right out need it sorted ... just say if i get it recored what can it be p.s heater is dissconected on it house go's around motor n go;s back near water pump could that make it heat upp?????
ok i took it out flushed it as said has no themo in it allready alot of brown water came out and some slug flushed everythink motor radiator out has to help was alot of crud in there i brogut a raditor flush aswell try that see how i go i will let u all know how i go....... does any1 have a ruff price on a reco one????? if its not the radiator what eles could it be???
hey everyone realy new to the corolla side iv always wanted a 55 and finally got one now to find it heats up a bit is there a simple radiator upgrade ? or should i just get a new ?secondhand one i think the core is blockd... is there a way to unblok it ??? all help would be great
f.i.t.
