Putting Vn Rear Sway Bar In Ae71
Will do mate, hopefully it does, I've heard of people doing this before and the sway bars do look very similar...
Thanks for the info, Vn rear sway bars are 19mm thick and the whiteline ones are 18mm thick I'm pretty sure, i can get a vn swaybar for $50 from the wreckers where as a whiteline one is $250. The whiteline would be the better option but if it works $50 is pretty cheap :)
Does anyone know whats involved in putting a VN commodore rear sway bar in an AE71? Is there any modifications that need to be made in order for it to fit? Thanks!
Ae86 Coilovers In Ae71
Thanks heaps appreciate it!
Hi all, I know theres probably heaps of other topics about ae86 coilovers into ae71, but i just need clarity on one thing, i know that i'll need ae86 steering arms but can i get away with using my standard ae71 hubs and brakes? Will these bolt up with the coilovers? Or will i definitely need to get ae86 hubs and brakes as well?
16V Smallport Limiter Problem
Haha, na i don't know anyone that has one unfortunately, i think i might try the computer for now and see how that goes, thanks mate!
Yeah that is strange, yeah the engine seems to be running well, I'm not running any aftermarket rpm gauge just the standard AE71 Tacho, maybe it could be out? I have a spare stock computer, do you think it is safe to swap to that one and see if it makes any difference?
I've put a 16v smallport in my AE71 and for some strange reason the limiter is not there anymore? It used to limit at 7700 rpm which i think is standard for a smallport but now will rev to 8000 rpm and still not hit the limiter, ive only done this a couple of times as i don't want to hurt the engine at all, but just don't know why it isnt there anymore? Its completely standard with standard computer only mods are extractors and pod filter, any help is appreciated!
4Age Smallport Into Ae71 Loom Issues
Cheers! No worries i'll be sure to keep all this info you've given me when i put it in
Yeah off the ae92 loom, i may even be able to get away with leaving them unplugged This is my engine here, still need to get a few things: -fuel pump -surge tank -make the rest of the exhaust -cut and shut intake -etc etc lol
Cheers man!
Thats good to know then, i was going to go to the effort to find an intake and airbox so i could get the sensor lol
Oops will it still run okay if the sensor isnt plugged in?
Jossy
