Everything posted by Stuart89
What Roads Do You Normally Cruise
Snake Gully Road at the back of golden grove, range road gorge road, greenhill, up to lofty road just a few and chain of ponds
Ae71 Tail Shaft Into A T18 Diff
Hi All I recently had a drifting accident which has prompted me to get a new diff that happens to have been welded! But it is a t18 diff out of an te72 rolla or celica. Ive heard although the ae71's and the te72 both run the t50 gear boxes because the te72's are older the number of output splines in the gear box are diifferent? Any one know if this is true? If this is not true i could just run the t18 tail shaft with no probs to my gear box. If it is true is there a way to use the stock ae71 tailshaft and connect it to the t18 diff? Cheers for any help Stuart
Foglights.
Hey mate i recently bought a set of fog lights for my ae71 the work very well. I mounted mine behind the grill beleive it or not. even from there position they still work really well. The easiest way is to buy a kit from AUTOBARN MOTOQUIPE or SUPERCHEAP or another car shop i was lucky to find a kit for $40 from motoquipe but otherwise they are around the $100+ mark but i just used stock holes in the radiator support and bloted them straight on. sTUART
What Got You Into 'rollas?
Drifting! Got me into rollas cheap easy to work on, mates that have rollas and sprinters look that look nuts so i bought an ae71 my first and only rolla so far. But my mates ke30 is even better, just coz its got a 1j supra engine in it lol serious
Help New To Corollas And Think I Stuffed Something Up (wiring)
Thanks man I'm not that stupid ive already been told and looked into a 4age conversion or maybe even a 4ageze conversion for some sweet power and the only reason i was trying to put neons in is because i had them on my old r31 and didnt see much point in them lying around the house
DW All i found the fuse it was in the kick panel i did not know there was fuses there woo now i need a new fuse lol Thanks all youve helped
Ah is the tail lamp/ dash fuse in the kick panel?? hopefully it is make my life easy
What are the three inside, near battery and the 3rd
Ok cool thanks ill have a look tomorrow I'm hoping i didnt blow every glob that will be a bitch
well help me figure out what the problem is please ok I'm a tossa for trying to put neons in ok they arent connceted how do i fix the problem at hand
- Help New To Corollas And Think I Stuffed Something Up (wiring)
Hi Just bought an Ae71 and i was trying to install my old neons via the cigarette lighter light, the little one that comes on with the parkers and headlights while doing this i heard a sizzle and tryed the parker lights and they stopped working along with the dash lights? I called out the RAA and the told me there was no power getting to the dimmer switch which could mean an open circuit any way has this happend to anyone or know how to fix it my mate also has a ke30 with the same problem but we can't figure it out Cheers for any help Stuart - Help New To Corollas And Think I Stuffed Something Up (wiring)
