toyke70
    7
Everything posted by toyke70
  1. I am after the colour and location of the standard tacho wire in the engine bay of a KE70 to hook up to aftermarket ECU running 4age with single coil. or the colour of the wire at the back of the dash. Any help would be appreciated.
  2. Name:Shane Car:82 KE70 X 5spd (soon to be turbo!!!!) Motor & Driveline:4AGE - T50 from AE86 - AE71 Tailshaft - Stock Diff ( Needs to be welded) Suspension & Brakes:Stock Wheels & Tyres:Stock Interior:Stock Body: O.K. Brown with usual rust spots Other:Surge tank , Hi Flow Fuel Pump
  3. Cheers mate...... I think my old one is 660cca so will get something similar. Thank You :lolcry:
  4. Hi All, It's come to that stage where i need to buy a battery to check all the ECU wires are correct and need to know if a standard KE70 4KC battery is enough for the 4AGE ( Enough CCA) or do i need to buy a AE82 ( what my GE is out of) ??? Any help Appreciated, Thanks all.
  5. I know what you mean buy it looks better with the "factory look" everything else in the rolla is how a AE71 should be except for the Gearbox is still being held by a Car Jack. So looks like i need to find a rocking horse that poo's :)
  6. Hi All, Sorry if you have been asked before but need help on fitting my T50 to my KE70. I have purchased a AE86 Gearbox Xmember mount and bolted it to my Standard 4K 5 speed Xmember which bolts to the T50 but the floor Mounting holes don't line up. Now can i just re drill the floor holes or do i need to modify the xmember as i can't find a AE71 xmember. Any help would be appreciated.
  7. Hey All,:monkey: Just after some advice .... i brought a KE70 and got heaps of spares including a couple of manual gearboxes but as i have no shifter to check does anyone have a idea if you can tell externally between the 4speed and the 5speed as i want to get rid of them (2). Any pointers would be good. Cheers, P.S. This has probably been asked 1,000....."s of times but i couldn't get any matches with the forum search. :)
