What's Easier To Put In Ca18 Or 4Age
How should I do it
Is there any other toyotas that I can go to u pull it and rip em off.
What about tail sharft and engine mounts do you have to change any of that
Hi there I'm stuck on what I'm going to put in my ke70 I wanna put ether a 4age in or ca18 but depends what ones easier I know its not going to be just put it in wire it up n go but I just want to know what you have to do to put ca18 in and what you have to do to put 4age in
- Ca18
Need Help
I donno I ended up getting help off aus12.com.au
Need Help
so the two wire coming out of my dizzy red & black can I put them on the coil red to red black to black?
Need Help
Hey mann i got a new dizzy and it has,a wire coming out red and black but there no where to connect it to where do you have yours
Need Help
hi lads antill I get a new engine. I'm going to ge the 4kc going I went up to repco today and got a new coil and a circuit tester. all tho the new coil I got says not to run with resistor is that ok? and the old coil that was in it hade a resistor. there was a black and light orange colour wire that had a circuit going thro it and went on the old coils resistor the old coil was a c80r and the new one I got is a c80 with no resistor and another thing is there any photos around of good engine bay pics of distributor and coil set up because I think myns got made wiring problems aswell when I try to crank the car the temp starts going up all the way to hot if I keep cranking it and that's with the car not going and and there just no spark what so ever.
Need Help
Cheers man and ive been looking and I'm going to covert it to rb20det and make some power for the little rolla :)
Need Help
Yeah theres spark between the point but not that strong but the battery was a little flat. And yes ill be going up to repco and getting a multimeter. do you know of anyone who would come have a look just at the engine in general because I'm normally a nissan man but latly its All about the rolla main thing is I don't know anything about the 4kc engine and would like to know is it worth keeping or doing a engine swap when I got $$$
Need Help
Hi there I've just bought a 82 ke70 for drifting I got it cheap because it hade no spark I've replaced the points and theres still no spark in the plugs do I have get a new coil or disturber.
the rolla
