5ARJ
  1. If you want something big in charge you can use 4age alternator and custom bracket.for yhr pulley you can use 7k pulley and ream the hole a bit to fit.ive done before,its good if you fitting with an extra gadgets.
  2. I'm using 7k alternator with internal regulator.direct fit.need to rewiring to socket wire using 3 wire.running good than stock alternator.
  3. Can 7k gearbox direct fit to 4k engines
