Ke70 Alternator Question.
Hey all,
So i'm not quite too sure about alternators in general; How hard are they to find for the 4K motor and roughly what's the going price for them? Also what would be the labour price for one to be replaced (Just so i don't get ripped off, :P).
Justin.
  • 2 years later...
I'm using 7k alternator with internal regulator.direct fit.need to rewiring to socket wire using 3 wire.running good than stock alternator.
If you want something big in charge you can use 4age alternator and custom bracket.for yhr pulley you can use 7k pulley and ream the hole a bit to fit.ive done before,its good if you fitting with an extra gadgets.
Change it yourself, there is nothing easier-
Pull yours off and pull it apart to check the carbon brushes, as they're the only parts that wear out (except the bearings, which you would hear)
What is wrong with yours?
