Craig_ae8670
    32
Craig_ae8670's Achievements
  1. Can be done using any model 3s but the altezza beams RWD one is alot easier. The 3SGE has all the bolt holes for engine mounts (i know my mr2 gen2 3s does) so it would just be straight forward with engine mounts. A 4y or 2s bell housing mates it up to a W5* gearbox then a cross memner will need to be made for that. Then the intake manifold needs to be modded as the throttle is facing the wrong way and at a guess the maniolfd is too tall and will foul on a few things. I'm doing this into a KE70 at the moment. I'm using a gen2 3s from an mr2. I already have a modded intake manifold using silver top 20v throttles. I have a 4y bellhousing. Ill be doing a write up as i go along as how I did it all.
  2. Spotted raven in the pano going down bridge rd heading towards the city at about 725 this morning
  3. Welcome dude I remember this car. It use to be silver? You were at an INFMS car club meet up one time ages ago.
  4. I like the conversion. Wouldnt do it myself but its something different. BUT on the other hand. DUDE WTF IS WITH THAT BODY KIT????
  5. Spotted Valandor in a u park thingy this morning just off north tce other side of the road to the cas. I was the door walking around and gave u the wave and yelled something out about rolla club when i sen the sticker
  6. No wasn't rob. I know what his looks like
  7. Spotted a mustard KE25 near melb st at about 8 this morning. Had P Plates in the front window. Dunno if their on here didnt see any stickers on it....
  8. The XF falcon setup can be mabe to work but you need to start with the stock map sensor. I haven't looked into it any further as its too much money,time and effort when i can get better performance from EFI. I was only looking into it as a cheap way out. Even with the sigma dizzy its still going to take alot of effort with dynoing and dizzy recurving and shit. It would be alot harder to recurve it as i am planning to run after market cams aswell.
  9. 4ac=different 4AGE=SAME :D The 4AGE and 4AGZE both have th same timing gear. The belts are the same. Cam gears and crank gears are all the same. The only one that is different is a 20V
  10. Cheers dude ill let you know
  11. Ok i have found a guy on 86dc that is selling twin webers with a dizzy. He reacons its a sigma dizzy. I thought that the internals had to be swapped but going by the picture it looks like a stock sigma one. I might head down to u-steal-it tomorrow and see what i can find out. EDIT: Hands off people the dizzy is mine if hes seperating.......
  12. Ive got the choice of twin solex or dellortos both 40's. Can get either one for anout $100 for the pair and can get a HKS twin carb manifold for about another $100 with linkage kit. I have been talking with my boss at work today (I'm an apprentice mechanic) and he thinks there might be a modual that you can wire up to the stock dizzy and use a map senor to give it then advance. Works the same way as the XF falcons do on the carb'd modles. I need the advance as i will be running some sort of cams. Hence the reason why it will be cheaper. I don't wanna have to spend $2000 on an aftermarket ECU i'd perfer to spend that on my 86. The manga dizzy's do work but still don't give any advance as you have to swap the internals over to the 4AGE dizzy. I was told about that one by a guy that ran twin 45 webers on a 20v. Ill let you guys know how the XF falcon style goes after i have done some more research on it. Ill will be ringing up are EFI parts people through work and they will be able to give me some ideas. Cheers Craig PS: Raven i was going to steal a 4AC dizzy from u-steal-it and see if it fits
  13. Thanks boys but i need some sort of advance. Its going to be daliy driven.
  14. Hey guys, I will be building up a 4AGE running twin carbs for something different and also for the fact that i can get the carbs cheaper then a new inlet manifold with the acc.. Now my question is does anyone now what dizzy to run with this?? I tried searching all the forums ie toymods, rollaclub, 86dc... Or even better does anyone know of a stand alone ECU that only controls the spark and not the EFI??? Any help would be good Thanks in advance Craig Edit: I was think of using the stock ECU to control the spark and advance but i didnt know if this would work. So i would wire it up to just the dizzy and not any fuel injectors. Someone know if this will work??
  15. AJPS has 15x8 -4 super lights that are hub centric (normal ones arent) They are around $1000 for the full set.. Hes in adelaide though but can ship to you for extra AE86 parts shop Location: 4/18 Brian Road, Lonsdale 5160 Website: www.ajps.com.au Email: [email protected] MSN: [email protected] - Add me (08) 8357 2709 0407716089
