Ethan.ke20
    6
Everything posted by Ethan.ke20
  1. I’ve got t3 weld on coilover kit on my struts
  2. The t3 aftermarket LCA’s extend 1.5” (38.1mm) so they should adjust enough to fit just wanting to run something aftermarket instead of stock LCA’s also need to find out if ke20 ball joint will fit into ke30 lca’s? or if I’ll have to get my steering arm lathed to suite ke30 taper ball joint
  3. Hi, wondering if anyone could tell me the length of ke20 and ke30 LCA lengths? (Centre of ball joint to centre of bushing) also want to know if a ke20 ball joint will fit into ke30 LCA? And if ke20 caster arms and sway bar link bolt in to the ke30 lower arms? basically wanna use the aftermarket T3 ke30 LCA’s in my ke20 https://technotoytuning.com/toyota/ke30/front-lower-control-arms-ae71ke70ke30-corolla cheers.
  4. Thanks mate would be a lot easier if T3 made more ke20 products/gear haha
  5. Are they basically the same car? (Other than engine and body shape and some interior) Know if the brake kits that are made for the te27 fit a ke20?
  6. Hey guys Just wondering if there’s a difference between ke20 lower control arms and te27 lower control arms? wanting to run the te27 gtx2 T3 lca and caster arm kit on my ke20 cheers
