fozz
    123
About fozz
  • Birthday 08/23/1989
Contact Methods
  • Website URL
    http://
  • ICQ
fozz's Achievements
  1. no s13 have irs
  2. I'm in
  3. is this cruise ever going to happen?
  4. damn you loom
  5. wats wrong with your car
  6. ill come for a cruise
  7. +1 Ill definatly be there now my car is running good
  8. i might come
  9. there is a cable cluthc t50 it comes from a jdm ae85 with a 3au
  10. I'm assuming u want to mount this in a rwd you will either have to cut a hole in the firewall or run aftermarket computer as the dizzy sticks out the rear of the motor
  11. ^^ YES
  12. fozz
    Ke70
    if you are in qld u can't do any thing that requires a blue plate if u are on your p's as for motors most of the k series motors are old and sluggish the only one that is half decent is a 7k and there worth a fair bit now days
  13. I'm doing a blacktop sr which is similar they both use the same mounts. kaizen garage in brisbane make a mounting kit for ca/sr conversion. you also need to get a custom tailshaft. also when doing the conversion it is best to use a rb box with a ca or sr bellhousing so the shifter sits in the right position all in all its worth it as it will beat the pants off any 4age
  14. theres one at eagle wreckers in yatala has anyone seen an ae86's at the wreckers?
  15. fozz
    D Cars - Seq
    lime green ford typhoon (got pulled up by it the other day) red ss comodore seen this pull up a soarer in sufers black volswagon golf near the casino
