- The Red Baron Ke25
Gjm85'S Ke20 Build
Not having much luck, I brought my flywheel in to guy in Bris machined and lighten within the hour, sounds abit rough how long the head is taking, clutches are over rated haha can still drive her home
5.5 Mm Shaved 4K Head
is the surface of the head grinded in to the spark plug tubs? you know if it shaved a lot when it gets into them
Roo's Ke20
Yea it's alright my other 2 ke25 are better thread will be going up soon for them
Roo's Ke20
hey as some of you already know that i had a ke70 with a 4agze then got a ke20 with worked 4k in it, selling my ke20 was the biggest regret i had so from that point i always wanted to get another one so now I'm back in the rolla scene with a fleet of cars. so i started by finding a ke20 on gumtree, car was in pretty bad condition and missing a lot of parts. it was mid way though a ca18det conversion when i snapped it up as i said she was had a ca18det and rb20 gearbox in it before i got it so was left with cut tunnel :S first thing was to do is weld a tunnel in so after hours with the welder the whole was filled, i planed to put a 4k in so next i fitted a 4k and 5speed box. gave the engine bay a bit of matt black paint to get rid of the horrible mustard then started on stripping her back to bare metal for the respray and her in epoxy primer and that about how she stands, got the bonnet and boot and doors in epoxy and just fixing some rust in the bonnet and boot will hopefully get the whole car in 2k primer soon then will be getting and nice white 2k respray so plans are just nice and stock 4k low on stock wheels kind want to looks like original as i got 2 over cars with some crazy plans for thanks roo
Buttercup The Ke20V Blacktop
You will have bugger all room at the back I had to change my water fitting on the back of my 4age 16v to a rwd just to stop it hitting the firewall
Ali's Ground Up Ke25 Rebuild
doesn't look to bad, but its good that you are find it all now so you can fix it before it gets worst good luck with it will be keeping my eye on the thread as I'm doing pretty much the same build but a 4agte instead of 7age
Another 4Age Ke20
how did the brakes go with the paint on the rotors? that would ok been a scary first drive
Ke26
if you ever want to part with that air con unit hit me up
Krems Ke20
what metal did you use to patch the rusted bits? need to do it on my car
Cruise Time Ffs
any one want to give me a 4k + box and ke20 interior i can try get my dirt bag on the road
Ae86 Diff Center In To Ae71????
nope, its a different diff ae86 would be a s or t series diff ae71 would be a bw
Roo's Ke20
they all live on the brown car, the yellow car had rust in the rails, so it went all onto the brown one bonnet is on it, i sold the diff centre to the guy with the matt black ke20 drag car, rest of the diff is living at the tip, lcas went with the car
Bruce The Wagoose Ke26
rip a skid, what you doing today might have to come checky it out
