Ae86 Panels Interchangeable?
ok know i know its a stupid question though id thought id ask any way. are there any other corollas that have the same type of front quarter panels as the ae86 corolla eg will the ae82 front quarter panels match up or are they different, some help would be great. thanks in advance dean...
Ae86 Sprinter, Twincam Or Single Cam?
i thought that this question might come up. the sprinter has rust like no other car though is not quite beyond repair its not my firt choice of car if it was the jap version it might change my point of view. thought it might be handy for parts for my ke20 and a possable conversion swap with engine, and after having a love for ke20 since i was young i don't want to let this one go. might stick with the 4age idea. thanks for all your help.
ok, and another maby obviouse question to some, is the 4ac into a ke20 corolla a common known conversion or is it a wiser move to stick to the k series engien's with the simplicity of the conversion, . are the gearbox from the ae86 the t50? . one more can you use the clutch master cylinder from the AE86 when converting a ke20 from cable the hydrolic just i may be picking an 86 sprinter and wanting to know of the parts that may be good to put in my ke20 corolla
hey everyone just out of interest did the AE86 toyota sprinters come out with two types of motors eg twin cam 4age and or some form of single cam motor. if the single cam what are the stats of the engine and pros and cons over the twin cam. thanks dean...
Home Spray Job?
buddy, its not that hard depending on what paint you are using. eg: acrylic or a 2pac enamil i think... its been a while. for a first timer acrylic is dead easy I'm no panel beater or spray painter and i painted an rx7 with not 2 many issues. prep work is everything, the actual painting is the easy part. my best tip is to take your time and not rush otherwise it will turn out half assed. peace dean...
Ke20 Rim Offset?
ok buddy thanks for the quick response
Ke20 Rim Offset?
hey I'm looking at getting a set of rims from a mate that has an early modle mazda rx2 with a stud pattern of 4x100, I'm just wanting to find out whats the offset that i can put on my rolla and if anyone knows if the early modle mazda rx2 rims will fit my rolla ke20 thanks in advance. deano...
Carby Feed 4age?... And 7k Oil Pick Up Question.
hey everyone, at the moment I'm looking at doing engine conversion to my ke20, at this point I'm going to be keeping my options open in regards to what engine i will be putting in the car, i have been looking at the 7k townace conversion or the 4age conversion. now I'm just wanting to know is it possable to have a carby feed 4age and the legality of it been carby, and not having all the emissions gear. and with the 7k motor i know about the modification to the sump and that is no drama. though i have heard that the pick up is to be modified. what is involved in the modification of the oil pick up? thanks in advance dean...
Ke30 Parts On A Ke20?
ok thanks for the help rego is coming up and unfortunatly the car got a slight love tap in the front and well the rest is history,
hmm ok thanks mate
hey i have a ke20 and it had a slight front end collision and messed up bonnet, front grill and left hand quarter panel, is it posable to transfer parts from a ke 30 onto the ke20 or are the different. advice needed asap as i have rego coming.
aroome
