There are some photos of the techno tuning mounts in this thread. I am installing them in a KE30 with a 4A motor.
Tim
http://www.rollaclub.com/board/index.php?a...&pid=428613
I am repairing my daughter AE82. I have the passenger side drive shaft out as it seems to be loose in the transaxle. I want to check the dimensions of the inner shaft as goes into the gearbox ? The previous owner did many bodgy things to this car.
Tim
The bore of a 2tg will go to 89mm with a 3T crank you get to 1941cc . A 2tg block generally needs to be adjusted for clearance for the rods at the base of the clylinders.
Tim
Here is the T3 mounts up close just rough fitted with old 4A block. The mounts are AE71 rubbers. I need to deal with the lip on the crossmember the K series mounts sit on.
Tim
