HarlemSessions
Everything posted by HarlemSessions
  1. "T-Piece" your return line back into the fuel line going to your pump. :dance:
  2. Sounds good to me. Is there a specific reason for which you run 3k pushrods?, do you have any spare that you want to throw in with the carby young Mr Felix :hmm: What did you do to run said gutted hydraulic lifters?, I read this previously but am having trouble finding it. I'm building up another K motor for my brother and decided to try a 5k this time (though i might keep it :lol: hahaha) Cheers
  3. I wrote this on an 2 year old thread a few minutes ago, but since it did not relate to the thread title, i thought i would start a new one. Soooo... If i am running a 5k Block and head, with toyota 3F (Toyota KM36RV-JR,Part No. 13751-61020) solid lifters, will the A12 pushrods be the go....depending on the post height of my 4k rocker gear?, Is there more than one length of A12 pushrods? If i put up a pic of my 4k rocker assembly, can someone tell me whether it's the tall or short version?, or can someone give me some measurements or a way to tell them apart, as I'm having difficulty finding 4k rocker assembly post height measurements on the net. "I have some solid lifters that will suit your 5K block but you will need to change to a flat tappet cam from a hydraulic cam", This was said earlier in the thread, to change to a flat tappet from a hydraulic cam...how do i do this?, is it simply a process of when i take in my 5k cam for a regrind (Tighe 104), i tell him that i want it ground for a solid lifter instead of a hydraulic?, or... Can i replace my hydraulic lifter 5k cam with my solid lifter 4k cam?, will this be a DIRECT swap? Help :lol: :hmm:
  4. Soooo... If i am running a 5k Block and head, with toyota 3F (Toyota KM36RV-JR,Part No. 13751-61020) solid lifters, will the A12 pushrods be the go....depending on the post height of my 4k rocker gear? If i put up a pic of my 4k rocker assembly, can someone tell me whether it's the tall or short version?, or can someone give me some measurements or a way to tell them apart, as I'm having difficulty finding 4k rocker assembly post height measurements on the net. "I have some solid lifters that will suit your 5K block but you will need to change to a flat tappet cam from a hydraulic cam", This was said earlier in the thread, to change to a flat tappet from a hydraulic cam...how do i do this?, is it simply a process of when i take in my 5k cam for a regrind (Tighe 104), i tell him that i want it ground for a solid lifter instead of a hydraulic? Help :lol: :hmm:
