I'm not going half way across town to get a chassis code number. if you guys can't ell me what will and will not fit buy the year and trim model you can't help me at all. i don't know how things work in other countries but all you need to buy parts here is a year model and trim lvl.
ok just learned the rear end wont work its a celica gts with irs. i was told the 3tc and 22re use the same transmission? i can make the clutch pedal work as long as the master cylinder is close to the correct size. i have good fab mechanical skills and acess to a car lift and welding equipment i have no idea the chassis codes for the celica why would there be more than one kind of 84 celica gts coupe? my car is a te72
i don't know the chassis cod eof the celica its just an 84 celica coupe gts. my car is a te72 with 3tc and auto trans. the celica has 22re and 5 speed trans
ok i posted this in the wrong forum b4 i think. but anyway, will the rear end, front brakes, trans and pedal set from a 1984 celica fit on my 1980 corolla hatchback?
I recently happened apon an 84 celica gts. will the rear end, front and rear brakes transmission(car was equiped with a 5 speed), and pedal set work on my 80 corolla (has 3tc and auto transmission) ?
