Computer Location
Cheers! that makes things a bit easier
Computer Location
this may be a stupid question but after lots of searching I still can't find where the computer is located on a 89 sx
Starting Trouble
Is there a bleed valve? I topped up the wated, it was only down a tiny bit but I thought the last person may not have bled it. I'm begining to think il have to remove the head and have a look. I have either replaced or tested most components that make it go. plugs, leads, coils, (havent done distributer) puel pump, pressure at regulator, injectors return line, map sensor, all the fuses, compression, plus a few others that I can't think of. tried the battery to reset the computer but nothing changed.
Starting Trouble
So leave the positive still connected when I do it? I left it running for around 15 mins, the temp gauge came up, don't remember how much tho
Starting Trouble
The only other problem was it had been sitting and had some water in the fuel tank as the fuel pum had rusted to the point of not working, so i thought this or the imobiliser could have damaged the injectors
Starting Trouble
Water is fine, as is oil. to have this much trouble from a BHG would it show up on a compresssion test and possible drain the water into the oil. Not sure about the computer
I Have A Crazy Idea For My Rolla To Run Past You Guys
Even the 3.0 triton v6 goes suprisingly well Ive got the same set up 2wd 4wd chasis. I was going to turn it into a mini truck but don't think i can be bothered. If they werent so heavy they would be really good
Starting Trouble
I still havent got this car running properly yet. I havent done anything on it for quiet a while as I don't really know where to look. I have got it to the stage where it will start and run but it idles at around 3000 rpm and blows HUGE amounts of white smoke. It will fill the shed in a matter of minutes. The smoke gets much worse as it starts to warm up. I have checked the compression on all cylindars and is fine, also a friend put a fuel pressure reader on it and he thought it was about the right pressure. I just purchased seca with a 4age in it with a shot gearbox so I should have all the parts needed to get it running. Any thoughts on where I should start?
Adjustable Fuel Pressure Regulator
After lots of searching and not finding much, How do you go about fitting an adjustable fuel pressure regulator. all the ones the i can find with a gauge are ones that locate on the fire wall. they have lines supplied with them for fuel and vacuum. Where I'm not sure is gow you can attach it to the fuel rail where the old fuel pressure regulator was. I have a major over fueling pfoblem and haveing a gauge woul help me figure out what is wrong
Starting Trouble
It was starting for a second and running on its own. now it wont run its only turns over on the starter. I havent changed anything since last night and i was going to test the injector signal when it started but now it wont. the only thing that changed was the battery was disconected as i don't have one for it yet
Starting Trouble
One step foward 2 steps back. It wont even start now but i figured out it isnt getting any power to the injectors. so this brings me to where do i look to solve this problem
Starting Trouble
When i got it the siron hazard lights were flashing, the siron had been cut and it wouldnt turn over. the fuel pump was no longer working but i have since put in a new pump. I have disconnected some of the wires i could trace. Now it will stat but stalls every time. If i disconnect the immobiliser it wont fire it just turns over endlesly.
Cheap Engine Mods For A 4a-ge
Is there any plug and play piggyback computers available for the 4age
Few Questions
I have found the plate with the paint code as well but neither have that info
Few Questions
Its not there it only has the vin number on that plate. the engine number is normally stamped into the block but not sure where
Muffo
