kexxxclub
    62
Everything posted by kexxxclub
  1. thank you to all who posted for me. I am still thinking about buying one. I'm sure i will when one is re advertised. I have bought off gira before and he was gr8 with what i received. couldn't complain at all . The one for sale now, looks as though the face of it has be brush with steel wool . This is why i did not bid on it . Who knows maybe its just the pic
  2. hi, I'm thinking of buying the instrument cluster off ebay for a ke25 / te27, its the one with the speedo and a separate tacho, with the other gauges inbetween . Question is, will this just plug into my ke20 or is there different plugs on the back. If anyone has fitted one of these, your help would be much appreciated . the one is pictured is the one i want to fit to my ke20
  3. Nice work there, keep it up , it will be all worth it when its finished . A+
  4. make sure all your earths are fixed to the car tightly and clean. Then need to check fuses etc . It sounds more like a timing problem or ignition problem . Do the comp test , it will give you a start. Have you checked the fuel quality that is in your tank? squeeze off the fuel return line and try start the car. It may help start it. Possibly injectors could be clagged, but i doubt it , unless you picked up a heap of crap in the fuel . Are all the air cleaner hoses tight. EG from where the airflow meter is etc. if there is a leak btw the airflow meter and the throttle body , your car definitely wont start or run as rough as guts Make sure that the crank is on no 1 Top Dead Centre. do this by removing no1 spark plug. Rotate your engine till the piston is in the full up position, and both valve on this cylinder are closed . Then check all your timing marks are correct .
  5. gr8 car , look forward to seeing you out and about. i should have mine on the road by christmas, for summer . What part of melb u from ?
  6. tired that, wont seem to line up. I'm thinking maybe the ke20 ashtray bracket is shorter than the ke25 bracket. Dougy is it possible to take a pic for me, if you have a spare ashtray bracket , it would be greatly appreciated $
  7. where are u gonna cruise? Frankston hahaha . Then you'll be showing up all the single mums in there camira's :sob:
  8. hi, I'm trying to fit the plastics to my ke20 . The ones that fit to the bottom of the dash board across the front. I have the plastic covered ashtray. My problen is, the surround that goes around the ashtray, has four mounting holes. two right underneath, and two at the top. When i place this against the dash the top 2 screw hole positions, don't really line up with anything. Looks as though it screws into the bottom of the heater control panel. In the pictures i have attached are the two holes that I'm asking about. (They are the ones with the red circles around them) If anyone has a ke25 , it would be much appreciated if you could take a pic for me to show me exactly what or where these 2 holes match up to to be fitted thanks
