ke cruzer
    7
Everything posted by ke cruzer
  1. i just bought a ke35 coupe speedo for my ke55 coupe everything fits and works except the speedo out put is different am i able to just switch the 55 speedo cable with a ke35 coupe so it will suit the speedo
  2. my ke55 coupe has ke30 sealed beam lights and i was just wondering if i can get a xenion sealed beam conversion kit i have seen other 55 coupes with them ( do i have to buy a kit) if do where .
  3. the belts at the right tension i think its just a faulty job hes already rip me off 135 bucks ill just cut my losses. ill look for a different alternator somewhere else.
  4. i just got my alternator back from the auto electricians for a reco and it charged at 14.0 volts for about 2 weeks and now the weird thing is it only charges as the revs climb and when the car idles its usless what could be the problem (regulator) btw its for my ke55 coupe
  5. the pin size hole is in the corner of the out let on the water tank at the top ,the core is fine and in good nick
  6. as you know my ke55 coupe is my first car and my radioator has got a pin size hole where it is leeking fluid from what should i do weld it close or use metal filler open what is best for it to solve this problem
