TARAKAN
    13
Everything posted by TARAKAN
  1. i think the ill just do the timing belt and put everything to TDC. the cranks is set to 20 when the camshafts r at TDC. so ill do everything all over again and see what happenes. I'm running ADM ECU out of an AE82.
  2. It is EFI. what do you mean by check plug? which one is it. i don't think that anything is shorting out. I can put everything to TDC and the car will run fine. it just that i gota do that everytime because once it stops and i try to start it again the timing is out.
  3. After finally getting the car to run now i have a different problem. I can't seem to get the timing right. I'm pretty sure its the timing. the car bogs below 4000rpm and when i try to accelerate hard at a constant speed like to go up a hill or something it feels like ther is no power. Sometimes when i put it all to TDC it runs absolutly fine until i turn it of. once i turn it off and try to start again it idles like crap and doesnt want to rev at all or it starts to choke and backfire. any hepl would b greatly appreciated. thanks
  4. had a look at the car again today. it has power going to the dizzy cap but not enough. when we measured the power in the dizzy in my friends 86 the power jumped massively but in my car it sort of stayed the same even less at times. [
  5. i got of work a bit earlier today and had a look at the car. it has no spark when i crank it but it does have spark when the key is initialy turned to on. so I'm gessing its the dizzy not sending the signal to the coil? any help woould be realy good. thanks!!!!!
  6. i gess i gota see what my friends coil does. but if ihas spark technicaly it should work but it would have a miss in it or something. but I'm not sure how to wire it up. i gota a manual 4 it. done everything by the manual yet still nothing.
  7. yeah we disconetced the battery. idk know why it does it but it sparks when the ignition is on.
  8. i just don't see how pulling the geatbox out would stop the spark. there is no wires going to it. do u wana come take a look at it. maybe ull see something i can't. or not. i can't realy see what else i can do .
  9. it sparks without cranking too. i have noticed that when we were cranking the engine over in my friends car with the dizzy cap off it made a ticking noise but when we did it with my car no ticking noise. I'm not sure if it sparking all the time is bad.
  10. they look good. i have tried 3 dizzies. i don't knkow if it will have anything to do with the ignition but we pulled out the gearbox to do welsh plug then we put it back in and the car wont start. yeah the dizzy cap and rotor both look good. maybe i need to reaplace that module inside it but i can't find any in brisbane ive asked almost everyon and looked all over on the internet. realy don't know what it can be.
  11. hi thanks for replying. with the ignition i have replced coil, the iginter is working, I'm getting spark from the coil to the dizzy. ive put new leads, dizzy cap and rotor but still i can't get any spark from the dizzy. we tried my friends ecu from his car and still no difference. we have also replced wiering going to the whole ignition system. ive even bought another ecu. i understand what else it can be. ive been trying to solve the problem fore 2 weeks now.
  12. hi i just wana know if anyone knows how to intsall coilpacks on a 4age 16v motor. ive heard that u can use sr20 coilpacks but what else would i need? how do i hook them up? i wana do that since i have a problem with my dizzy not putting out any spark. so it would b nice if someone can share their knowledge about how to install coilpacks and what would i need. thank you!!!! :blush:
  13. hey mate. i gota a question for u. maybe u would know. nobody else does. i got a ke70 with 4 age and so on. but its got a problem. it has no spark. it has power comin to the coil, power going from the coil to the dizzy but no spark comin out of the dizzy and the coil igniter works too. do these motors have dizzy problems or could it be an ecu? maybe it could b something else that u can think of. thanks 4 reading anyways.
