4K Starting Issues?
where abouts is the starter relay? because there isnt one in the fuse box behind the battery like all aus spec ke70's. otherwise i would've tried the one out of my wreck.
4K Starting Issues?
so i went and had a look at a mates K series repair manual. it says that there is a fuseable link somewhere between the ignition, and the starter. checked the fuse box under the dash, and the one behind the battery, but neither of them have a fuse for a starter. does anyone know if theres a third fuse box in a 70 panno?
4K Starting Issues?
yea twas a random starter. Tried another fully charged battery. still nothing. the starter wont even click or start it anymore.
4K Starting Issues?
I havent checked that yet, but all the radio, lights etc work for quite a while after turning the car off.
4K Starting Issues?
tried putting more demineralised water in it, took it for a drive, and the same thing happened. soo I'm charging another battery up at the moment to see if that fixes it.
4K Starting Issues?
hey guys, So I'm having trouble at the moment starting my 4k.After sitting overnight, it will turn over first click. after running the car, and then turning it off after say 10 minutes, the starter motor will tick, after two or three times of turning the ignition, then it wont even tick at all. first i thought it was the starter motor, so i replaced that, checked all the wires running to it, and they were fine. but it is still having these problems. any help would be appreciated. Cheers, Andrew.
Cheapppp!!! Nissan Bluebird S13 Coilovers
any pics? maybe keen.
Voodoo Ta22
any updates man? will have to catch up sometime!
R31 Skyline - $1300
auto or manual?
Sa: 200B 'Slo 810"
Hey guys, Up for sale is my 200b. I bought it 3 months ago as a run about, and i havent had any troubles with it. Ive rolled the front gaurds, aswell as flaring and rolling the rear gaurds. also have replaced the diff last week. The Good: New pedders springs and shocks up front Fully serviced, tuned and flushed 2 weeks ago Clean interior. The Bad: Rust Dents missing rear left window (will replace before sale) steering box has a little bit of play needs a respray Auto $1600 negotiable with 15x7.5 -5 mk1's and 15x6.5 Impul mesh, both with good tread OR $700 with stockies, with good tread. Contact Andrew VIA PM or msg 0414536187
Voodoo Ta22
any updates on this bess?
5K Rebuild?
will the VRS hold up ok though? because i had a VRS headgasket on my current 4k and it had a shaved head, and it only lasted a couple of months..
5K Rebuild?
Hey guys, looking to rebuild a 5K. it'll probly have like twin down drafts, cam, shaved head etc etc.. but i wouldnt have a clue where to find all the gaskets and bearings? I'm looking for a sorta high performance gasket kit if anyone makes them? could someone help point me in the right direction please?
Crusié Classic Cruise: Sunday Morning, March 13
I'm keen for this. i should have my car ready by then.
S12 Silvia
was worth a try :P
Hazzard
