Search the Community
Showing results for tags 'someone think of the children'.
Ok so here is my issue, Not long ago I bought a KE70, replaced the carburettor to twin su with lynx manifold, bought new headers etc. It ran once. Fast forward a week after that when my mate was around and I wanted to show off my mental 4into1 headers and how loud it was, wouldn't start though I might have been out of fuel, filled it up with some juice, still nothing. after a while of cranking it started, but was minimal (like, maybe 100) rpm, so low you could still crank it and it was ok with it. then it died. checked the distrubitor, rotor button was spinning freely, and points had weak spark, no problems. I'll switch it to an electronic distributor, get a bosch module, bosch GT40r coil, electronic dizzy, followed Jackbyo's mad guide to install a new electronic distributor (hence why I went with the coil and module I did) but still no spark, not from the coil, tested it with the old spark against the block or bolt head trick as well. made sure my wiring was all ok, still no spark. Re did the ground leads to the battery neg terminal and the engine earth, still no spark. Checked timing a million times ( the old rough TDC then rotor to spark lead one in the cap) ((dunno if that helps with anything)) I'm not great when it comes to car electronics, i've read that bad starters can draw too much power and kill spark so I'm thinking that might be my problem? Anyhow, this thing is killing me, the fact that it ran once, but not any more is driving me mental and ive scoured just about every lead I can think of. So now i'm coming to you lot for advice and hoping that you guys can point me in the right direction in regards to ideas or things ive missed that I should check Cheers in advance! ~Ethan
