Gday all just chasing some info from you AE freaks.
I just bought a 92 AE92 twin cam with a stuffed clutch and have a AE82 hatch sitting here for bits and would like to know if the box and clutch are interchangeable??
Havent done a FWD clutch yet but I'm sure theyre the same as all other Corolla jobs, easy when youve done a couple.
Cheers, Andy.
ok, if they are both 4AGE motors, than the gearboxes will both be the C52 5 speed. The gearbox it self should go in no worries, HOWEVER, the flywheels are both different sizes between the AE82 (bigport) and the AE92 (smallport) motors. I think the measurement are around 425mm vs 415mm, but i realy wouldnt know. Do a quik search on Twincam.org and you will find out soon enuff :y:
The gearboxs should be fully interchangable, aslong as you keep the appropriate flywheel, ie. if you put the AE82 g/box onto the AE92, makesure you keep the AE92 fly wjheel NOT the AE82 one :P
flywheels arnt an issue
use the clutch to suit the flywheel
easy as
when swapping boxes check the starter motor bulges.
if you have a one bulge and try and fit a two bulge it may interfere with the water pipes
OK what I've got is an 87 hatch with a 4A single cam and a 92 Seca twin cam.
Can I take the clutch out of the hatch and put it in the Seca or is a twin cam clutch different to the earlier single cam clutches??
I havent played with AE mechanicals yet.
  • 2 years later...
By 4ac single cam you mean 4AC? if so then it has a 6 bolt flywheel and is like a 200mm clutch, while the ae92 will have a 212mm or 215mm clutch and 8 bolts on the flywheel. So I don't think you can interchange them. I think that's answering the question lol.
shit just realised its an ancient thread... oops lol
Edited by quadeyquade
