Whiteline Springs
I had a look at the book and there is no part number.Maybe ke70 or ae71 might fit I'm not sure.
Edited by too quick
why set on whiteline?
the T18 has tappered springs in the front with and 124mm id top and 75mm id bottom. rear straght 106mm id. ground top with a 12mm gap on the bottom.
and i want white line coz they are better than most everything i've seen.
they could probably make them for you. they do alot of custom stuff don't they?
in all realities i believe the shocks you use are much more important than your springs
i went lowered kings in the rear of my 1g ke70 and paid 140...theyre decent enough, but i got koni adjustable shocks...and they are unbelievable! made a huge difference :D
