October 28, 200620 yr comment_148536 Hi all, My KE70 wagon was broken into last week. They smashed the front passenger side window. Does anyone happen to know if an 8 Corona window is the same size? The dimensions seem very similar and I have acces to a dead corona but I don't want to go to the trouble of pulling the window out if it's not gonna fit in the rolla. thanks guys matt Report
October 28, 200620 yr comment_148543 Not likely. But I can give you one for cost of freight only if you can't get one down there... I can throw it on a greyhound won't cost much Report
October 29, 200620 yr Author comment_148581 Tape measures are handy. As I said, the dimensions are very similar. There only appears to be about 10mm difference and it's hard to tell if they are actually different or it's due to the difficulty of measuring a window while it's still in a door frame. matt Report
October 29, 200620 yr Author comment_148582 Not likely. But I can give you one for cost of freight only if you can't get one down there... I can throw it on a greyhound won't cost much Thanks for the offer, mate. I'll see how I go and get back to you. Thanks very much. matt Report
October 29, 200620 yr comment_148583 Just pop it out and if its to big just cut it. Glass cutting is easy if you take your time. Report
October 29, 200620 yr comment_148588 I would think the glass is tempered, meaning it can't be cut or trimmed like normal glass. It's done that way so it will shatter in to small pieces if broken (as in an accident etc). Chris Report
October 29, 200620 yr comment_148592 Yea its harder to cut but it is doable you just need to take your time with it. We cut the quarter glass in our pajero, it takes a while but we got it done with out it breaking. :) Report
October 29, 200620 yr Author comment_148628 Yeah that's not a bad idea. I wonder how much a glazier would charge to take a piece off. Might look into it. matt Report
October 29, 200620 yr comment_148650 It'll work out cheaper running down to the local wrecker and picking one up from there then getting the glass trimmed to size. Not to mention that the glass in the 'rona might be bolted to the window mechanism differently to that in the 'rolla. Like i've said many a times - Take a sniff-and-taste test. Measure the glass, see if the measurements fit, pull it out and see if it lines up with everything. And if it does, sweet Report
November 5, 200619 yr Author comment_149653 Managed to get hold of a window eventually. thanks guys matt Report
