November 6, 200619 yr comment_149727 I am having no luck finding replacement performance strut inserts for my TE27 SR-5. The SR-5 struts are a bit shorter and fatter than the standard struts. Does anyone know if inserts from a wagon or maybe a Celica are the same part? I have checked the Tokico and Koni sites but nothing listed specifically for the SR-5 model Corolla. THANKS! Bill Report
November 6, 200619 yr comment_149746 You should be able to get some Bilsteins made to suit. Wouldn't be horrendously expensive..... Report
December 13, 200619 yr comment_155012 have you tryed kyb? they have good perfomance shocks at very competitive prices, much cheaper than Tokico, or you maybe be better (and cheaper) to swap to a diffrent strut.... david lawson is your man for the kyb's, or he might be able to hook you up with some others, 0407 716 089, tell him aaron from tassie sent you.... he is a good bloke and will look after you. Report
December 13, 200619 yr comment_155015 Ummmm.... The guy is in California. I'm sure there is someone local that can help..... Report
December 10, 200718 yr comment_214166 Just buy an ae86 front end suspension. Get the strut casing assembly... Try getting the spindles, the rotors, calipers, and brakes as well with the casing to make it complete. Do that swap and you'll find your self a little more ease finding parts for it ^_^. Report
