November 22, 200619 yr comment_151920 hi all, just a quick question. i've been searching through all of the different forums to try n find the answer but i was wondering if someone out there has put a fwd 4age into their ae71 or ke70, and when they got it into the car did the air intake manifold clear under the bonnet without being modded in another way than just the cut n shut to put the throttle body onto the front instead of the rear??????????? Report
November 22, 200619 yr comment_151922 you can get a sprinter inlet manifold which has the throttle body facing the front. big port only. Report
November 22, 200619 yr comment_151924 because if you do it will go right into the clutch master.... Report
November 22, 200619 yr Author comment_151929 hey guys thanks for replying so quickly. would u happen to know why the fwd manifold cut n shut will go right into the clutch master n the rwd sprinter manifold wouldn't?????? Report
November 22, 200619 yr comment_151932 An original RWD bigport manifold works good on RWD 4ages and what not, A FWD manifold needs to be cut n shut to be used on a RWD. If you just stick a FWD manifold on a RWD then it goes under the clutch master. Report
November 22, 200619 yr Author comment_151940 oh ok then. what if its a complete fwd ae92 4age going into an ae71????? this is why my question of getting it modified n if it would clear most things??? just trying to get most of the things done before it goes into the car which will be happening over christmas if i can work out the manifold stuff...... thanks Report
November 22, 200619 yr comment_151941 You will need to get the manifold cut n shut buy some one who knows what there doing and pick up some rwd extractors. Report
November 22, 200619 yr Author comment_151947 easily done........cut n shut will done by a mate of mine in brissie after i have found out if there will be any interuptions with clearances n exhaust n extractors being done by another mate of mine Report
