November 30, 200619 yr comment_153197 Hey. Ive got a 1994 corolla wagon and I need to put a new engine in it as the 4a-fe is dead. Am looking at either a 4a-ge or 4a-gze. Was wondering how much is involved in this conversion? What sort of performance I can expect from each option when I'm done? And what any major difficulties may be? as I'm on a relatively small budget but can do most of the mechanical work myself. Thanks Report
December 1, 200619 yr comment_153199 Is yours a 4wd wagon or just fwd ? and if it helps hit the search button. :y: Edited December 1, 200619 yr by too quick Report
December 1, 200619 yr comment_153281 I'm laying dibs that its an awd And like what too quick said - search But, yeah, if it is the awd from memory the gearbox is a little weaker then the fwd 'box Helpful info You could always take a different route and slide in a 7a-fe motor Report
December 2, 200619 yr comment_153363 PM kebin on these fourms....we just finished putting a 4agze into a 4WD wagon....alot of work! but he has photos of everything so he should be able to help you out. if u are going a ze with supercharger, the supercharger sits where the dif lock is located so u need to get rid of it and make up a custom one. Edited December 2, 200619 yr by ChrisGT Report
