January 10, 200719 yr comment_158767 My KE70 panelvan has a 4AGZE in it, with SC14 and Nevo pulley. I am pretty sure I used a KE30 Auto crossmember, which bolted straight in. For the pedal set, I could not get a AE71 set, so I cut the clutch section out of the KE70 set, and bolted in a AE86 clutch pedal box. It eventually damaged the firewall slightly as I did not bolt the clutch box to anything else, so I removed the instruments, cut a slot with an angle grinder and inserted a nut where there is a hole, for the top pedal box bolt. It has been thrashed like this for a year now no problems. Report
January 31, 200719 yr Author comment_161877 My KE70 panelvan has a 4AGZE in it, with SC14 and Nevo pulley. I am pretty sure I used a KE30 Auto crossmember, which bolted straight in. For the pedal set, I could not get a AE71 set, so I cut the clutch section out of the KE70 set, and bolted in a AE86 clutch pedal box. It eventually damaged the firewall slightly as I did not bolt the clutch box to anything else, so I removed the instruments, cut a slot with an angle grinder and inserted a nut where there is a hole, for the top pedal box bolt. It has been thrashed like this for a year now no problems. I went and found an automatic member out of a KE30, but it was still to big (long) Could you have possibly used one of an earlier model ???? Did it definately just bolt into your JDM KE70 Van ? Dave Report
February 9, 200719 yr comment_163362 It bolted straight into my ADM KE70 van, your van sounds spooky! Report
February 14, 200719 yr Author comment_164073 It bolted straight into my ADM KE70 van, your van sounds spooky! The Bloody thing is more than spooky...Its giving me the shits. I own 2 KE70 panelvans ( Both with Japanese Writing on the compliance plates) I am guessing your ADM KE70 has all english on the compliance plate. Your van should also be made by AMI (Australian Motor Industries?) Does your van have a low roof like the sedans? Cause mine does Is there any chance you could take a photo of the cross member under your car? Cheers Report
