Appreciate this kind of info isn't common knowledge but does anyone know for sure what the lift and duration are for the 2TG TRD cams (304 and 288 - appreciate that's the duration but you know what I mean)? Failing that, can anyone give me lift and duration for cams with more aggressive profile than the boggo factory items?
From my TRD parts catologue it has the following:
2TG Street / Track intake Cam Pt # 13501-TA051
Power band 3000-7500 rpm
Duration 304 Deg - 10mm lift
2TG Street / Track Exhaust Cam Pt# 13502-TA052
Power Band 4200-8000rpm
Duration 288 Deg - 9.6mm lift.
I have two sets of the above cams and have run them over many engines. Good for a 2ltr engine as long as it can breath with a good porting job. Have yet to try a 304 inlet with 304 exhaust as cams are interchangeable (both 2TG + 18 RG). The book says it is for track only.
Hope this is what you needed.
DMC
