32/36 Weber On Stock 4k Manifold
Hey all,
I am thinking about adapting a 32/36 weber downdraught carb, to fit on a standard 4k
manifold. Coupled with a 25/65 cam and a mild head port and polish job.
I was wondering if the stock manifold will flow well enough with this carb added,
does anyone know from personal experience?
or does anyone know what sort of horsepower you can flow with a standard manifold (with
the ends cleaned up and casting dags removed) ?
I have heard about plenty of people using these carbs on their k motors, but do not know how they
will go on the standard manifold,
Thanks in advance
How else were you intending to put it on?
I thought that the stock manifold was the only way unless you were going to spend a fortune on making a custom one up.
If you don't have a carby allready i have one for sale for $100 with a ramflo filter
I was otherwise going to buy a manifold to suit, as i think places like redline
stock manifolds to suit. I was fairly sure that these manifolds would be up to it, but
am not sure, anyone done it before/know how well it works?
Thanks for the offer, but i already have one,
Thanks anyway
The short answer is yes, that is the same setup that I have on my 4K and it works just fine. I would put some money aside for a proper dyno tune to get the mistures right and a dizzy regraph should be done as well to suit the cam you will be surprised how much better it will go.
Cheers
Paul
Cheers
Paul
Cheers, will do
I intend to get the dizzy recurved and the carb tuned, near the end of my
build so it all runs nice and smooth, thanks for clarifying that for me
