Hey again all :P
Seems i got anther problem with my Ke70 hehe.. It seems when i use reverse .. it sounds like I'm running cogs throw my car... ( its very loud while sideways ).This problem you can here in First as well.
Would it be that my gearbox is low on Fluid? And if so how do i check it and fill it up? ( I know its not in the engine bay )
Ive put more diff oil in cause i thought it may be that as that was leaking fluid. But its not..
And The other question i have is... Whats a good carby for a 4k .. I'm planing on doing big things to this engine.. Well not nessaserarly this one.. But a Recon 4k..
Cam.. Port Polish.. Headers all that.. But first i wanna make sure i can get the fuel in there.. Is this a good thing to do first? A mate said a 3k Worked carby is good for 4ks. Is this correct?
Thanks Russ.
The bearings could be shagged.
On the g'box just under clutch lever spring you'll find a bolt (something like a 17mm). Thats the g'box fill hole, you can check the oil level by sticking your finger (or a bent piece of wire) in there. The oil level should be just under the hole.
If it is low on oil have a look at the rear seal (would have to pull the prop shaft out)
Ok, Had fluid.. took it to a mechanic today .. he said its the bearings in the box.. so.. he said it will be cheaper to get a new box and put in then to do bearings and maybe the Gears them self to.
So.. I though since its a 4spd.. Could i get a 5spd box without having to replace diffs and shafts? Just swap the 4 spd with the 5 ? Ive been told from someone this will work on a Ke70.. But i hate only getting one opinion.. Thats why I'm going to another mechanic tomorrow :)
