October 16, 200719 yr comment_203604 as the hill climb gets closer its time to pull my finger out. BUT i have this diff i got with another car. but i have no idea what it is!!! its a jap style. (ie have to remove tail shaft to unbolt and remove centre). will i find an LSD for it cheaply??? or do i need to invest in axels and CIG the centre??? Edited October 17, 200719 yr by wilson_610 Report
October 16, 200719 yr comment_203681 could be a jap spec t series seeing it is a banjo front loader, has discs and coil sprung with link setup. Report
October 17, 200719 yr Author comment_203892 this is the best i can do... the camera in my phone is now f---ed but need to build new race car so it has to do till thats finished... Report
October 17, 200719 yr comment_203897 Take the center out and count the teeth on the crown wheel and pinion and divide them together and you will get the ratio. Also look to see if its and LSD, Look for clutches as they seem to be popular. Report
October 19, 200719 yr Author comment_204331 well i pulled the axels out tonight. they have 23 teeth on the spline. the axel bearings are about 2 inches long and the centre is open. the ring gear is roughly 4.11 well more than 4 turns but less than 4.5 but not too worried about that. just after what type of axles type i have so i can chase up an LSD center for it Willie Edited October 21, 200719 yr by wilson_610 Report
October 21, 200719 yr Author comment_204516 the ring gear measures 6.5" after searching a international spoonta site i found a sit that broke down (with pictures) the ae86 disc rear end... i have found i have Zenki axels Edited October 21, 200719 yr by wilson_610 Report
