November 9, 200718 yr comment_208270 Looking for these? -Rear shackle bushes - Front wheel bearings - Tie rod end 8| Report
November 12, 200718 yr Author comment_208758 I'm looking at starting a "substitutes" thread ie. stuff that fits on ke1x's off other models ie stuff at pinch a part? :) Report
December 20, 200718 yr comment_215989 Hi there, See attached catalogue. This place is in Sydney. bearing_catalogue.pdf Report
December 20, 200718 yr comment_216028 Looking for these? -Rear shackle bushes - Tie rod end :lolcry: The large rear shackles bushes are almost imposible to find through the normal sort suspension supplier"i tried for two months" Then i went to peders Frankston and they hunted and found that early cortina ones will sort of work if you`ve got a lathe that is. The small ones are available through peders etc. The tie rod end should be the same from peders aswell. If its the large bushes ill post the part number a little later. stu. Report
