Horn Doesn't Work
My horn doesnt work :wink:
Is there any other fuse boxes other than the one near the battery under the bonnet?
What other reasons could it be?
any help would be appreciated
It would be helpful to know what kind of car... but anyway
In most toyotas, the horn fuse is in the fuse block above the driver's side kick panel. Under the dash.
I can pretty much guarantee It won't be a fuse though. First check the connections on the horn itself. Pull them off, put them back on and give them a bit of a wiggle.
Sometimes it can be the contacts behind the buttons on the steering wheel, or, there is a small brass contact on a spring where the wheel hub meets the steering column. Sometimes the lube on these dries out and they bind on the contact ring and fly off.
Also the horn itself could be full of dust and crap or just rusted out. They do that.
Edited by 7shades
its a 1986 ae82 seca twin cam
do i just pull the thing thats says twin cam off? the thing in the middle of the steering wheel?
  • 4 years later...
hi guys
the wire from my horn up throu steering coloum doesnt reach my steering wheel what should i do ya reakon
any help would be sweet as i wont my car back on the road
cheers
Where is the horn in line Fuse located in a ke30/55?
